Optimization and Optimal Control
OptimalControl
<OptimalControl .../>
Attribute Comment Value
what= Select a time-dependent setting to optimize Select from: list(special = "SettingInZone")
OptimalControlSecond
<OptimalControlSecond what="Velocity-inlet" lower="0.0" upper="0.05"/>
Parametrises a time-dependend Setting with the value of every second iteration. Values inbetween are interpolated.
lower= Lower limit on the value of the Setting Value with unit (float)
upper= Upper limit on the value of the Setting Value with unit (float)
Fourier
<Fourier>
  <OptimalControlSecond what="Velocity-inlet"/>
</Fourier>
Makes a truncated Fourier transform of a time-dependent Setting (OptimalControl)
modes= Number of Fourier modes to use for the parametrization Select from: int
lower= Lower limit on the Fourier coefficients Value with unit (float)
upper= Upper limit on the Fourier coefficients Value with unit (float)
BSpline
<BSpline nodes="10" lower="-1" upper="1">
</BSpline>
Makes B-Spline transform/smoothing of a time-dependent Setting (OptimalControl)
nodes= Number of degrees of freedom (parameters) of the b-spline Numeric (int)
periodic= If the b-spline should be periotic in the control period Unknown type
lower= Lower limit on the values Value with unit (float)
upper= Upper limit on the values Value with unit (float)
RepeatControl
<RepeatControl length="100" lower="-1" upper="1">
  <OptimalControl what="Velocity-inlet"/>
</RepeatControl>
Repeats a control for optimal control
length= Length of the control to repeat Value with unit (int)
